2 Different AMS Heat Exchangers
681 Views 8 Replies 5 Participants Last post by  IridiumRS400
Font Parallel Rectangle Poster Communication Device
Font Gas Machine Output device Kitchen appliance accessory
I found 2 heat exchangers on the AMS site. Both looks similar but I can’t tell what the extra stuff with the Race HX is. They both say they fit OEM and utilize OEM hoses, etc. Can anyone differentiate the two?
Or does anyone know other heat exchanger’s that compare in performance?
See less See more
2
The "standard" size AMS HE is more than plenty for managing heat soak for 95% of modified Q owners, unless you plan to exclusively track your Q in Florida or Texas this summer.
The "standard" HE is a drop-in replacement, whereas the "race" HE will need some additional surgery on your Q to fit properly. The installation time for the "standard" HE is 4.5 to 5 hrs. When I had my Q, my local Infiniti service tech installed it.
Reactions: 1
I was confused at first as well.
The AMS HE is double the thickness (and size) of the OEM at 22mm, and the AMS RACE HE is even thicker at 32mm.
Most of the aftermarket HEs, including the AMS HE, are a tight fit. The extra bits that come with RACE HE is to allow installation.
Any HE is going to be better than the secondary OEM HE that looks more at home on a watercooled PC.
The reason why the AMS HE is popular is because its one of the few parts that are available through Infiniti dealers. This means that most Infiniti dealers can install it for you, emphasis on most, potentially meaning a parts warranty and/or maintaining vehicle warranty. It's best to ask around: While the Infiniti HE is basically just Infiniti rebranded (and marked up) AMS HE, some dealers will not deal with it. (Some dealers would back in the years when the Infiniti HE was out of stock.)
Warranty or not, most still have the heat exchanger installed at their Infiniti dealer due to the high risks of when air is introduced into the coolant and in the case there are damages (under warranty), then Infiniti/insurance have a more difficult time blaming the damage on you.
See less See more
My dealer provided a 1-yr/12k mile labor warranty for the installation of the Infiniti-branded AMS HE. When I had it home the 1st night, the IC Coolant Recovery bottle dumped some coolant out the overflow because the tech had filled it too much. I drew down the level with a turkey baster until the coolant was back in the MIN/MAX range. That was the only blunder from the installation process.
Reactions: 1
I can confirm that infiniti can (and likely will) make you put the stock HE back on for any indepth warranty work. Ask me how I know?
I used almost all AMS parts believing infiniti would not deny a warranty claim based on aftermarket parts and when I had trouble, they insisted I restore the entire car back to OEM before they would work on it any longer. They spent $10k trying to fix an electrical problem so I'm not sure why they cared about a heat exchanger .. but they did.
This was infiniti of Kansas city so be warned. Ultimately, I had to fix the car myself which was better than restoring the car to OEM.
My advice; if you are going to install an aftermarket HE, get the biggest one you can afford. Cooling is like money and horsepower; you cannot have enough of any of them and for all the work to install it, what is another $200 to have the best protection possible?
See less See more
That is entirely dealer dependent. I had no issues getting warranty work (engine, turbos, and transmission replaced) with a Fast intentions catback and AMS intakes, heat exchanger, and downpipes installed.
I think we can all agree that the decision to modify the vehicle while still under warranty (whether factory or extended power train) will be a roll of the dice.
In my case, the problem was very difficult to find; the dealer charged infiniti almost $10k trying to fix the issue with no luck. They ultimately decided the easiest way out of the issue was to decline the warranty because the car was modified. If your dealer needs to call the infiniti tech line, they can and likely will inventory the vehicle (they did on mine) . I was told everything on the car had to be OEM. I had a mild build; ARK Grip exhaust, AMS intakes, AMS race HE, HKS blowoff valves, oil catch can and AUCar mark 6 infotainment console. The problem was the car would go into limo mode with a exhaust camshaft position sensor bank 1. The dealer replaced the sensor, then replaced the camshaft sprocket (pulled the engine for that fix) and even replaced the ECU. I was without a car for 6 weeks before they simply gave up and sent me packing.
I am just sharing my experience and I am confident when I tell anyone reading this post that you do not want to be in my position. I could not get the car fixed and was left to fix it myself. The problem was ultimately a failure in the main F-harness and had nothing to do with any modification I installed.
I think more importantly, that infiniti (corporate tech team) will not honor any AMS modification. I paid the premium for AMS products under the assumption that there was a partnership and certain AMS products would not void warranty. I can tell you that if they "choose" to deny a claim, they can and when I went back through the fine print I found that AMS clearly states that their products may void the warranty.
I hope nobody goes through I did because I was left holding the bag and was lucky I could solve the issue myself otherwise the car would have been only worth salvage value and it had less than 30k miles on it.
I'm not saying not to modify, I am saying do so with the understanding that you be land yourself in my situation if the stars are not aligned well...
I have read in many forums to take all non OEM parts off before taking the car to the dealer and I am confirming that advice.
Best of luck to everyone and make the best decision for you.
See less See more
Reactions: 1
Like I said, it's entirely dealer dependent. My car was in on 6 or 7 separate occasions for warranty work in the last 13k miles and they never had an issue with my mods being left on. Corporate even came out to do a boroscope on the engine when it was consuming coolant and all they said was that I'd have to pay for them to reinstall my non oem parts (ldp's and exhaust). No big deal really as I basically paid $600 for a new engine and turbos. My service advisor also knew I was tuned and knew that I tracked the car. However, I did not have blowoff valves, and I know that dealers have taken issue with them on multiple occasions when it comes to warranty work.
Yeah, BOVs and OCCs seem to be the mods that get Infiniti corporate in a kerfuffle...
I had Turbosmart BOVs & Mishimoto OCC installed, but I removed them prior to bringing in for service.
Both turbos and engine were replaced under the Powertrain Warranty.
