1 - 16 of 16 Posts
Administrator
Are no flat tires really that necessary
The AWD models have run-flat tires meaning you can still drive on them when they're flat. The RWD models have an emergency tire repair kit because the staggered tires are conventional. If you go with conventional tires you should probably get a tire repair kit or a spare.
What are the best quality, but most cost effective run flat tires, 255/40/19? Not looking to spend $600. Under $350 would be preferable. Thanks.
Go to this link:
255/40R19 Tires
Filter on "Run Flat" (7 options):
Wheel Tire Photograph Automotive tire Light
Reactions: ozmoses
Thanks. Very useful. Do you know if the stock tires that came with the 2017 AWD Q60 were all season or designed more for non-Winter weather? I'm in Wisconsin and have used the same stock tires since 2017, although have only 12,000 miles on them and very little Winter driving. Just wondering if it's ok to go with the Summer runflats.
Go to this link:
255/40R19 Tires
Administrator
Below 45 degrees Fahrenheit most summer tires lose their performance so you decide. In freezing temps some will harden and the tread can crack.
Reactions: 351FUN
Like Bevo said, most summers lose a significant amount of their grip below 40-45°F. In addition to that they really shouldn't be driven on below 32°F, and they will be damaged when bearing a load (IE., just being on the car) in temps under 20°F
Reactions: Bevo
Forget run flats, move on all season or get a set for summer and winter.
This^. @ozmoses , I didn't even wait for my original runflats to need replacing. I just went ahead and replaced them after a few thousand miles with non-runflats and I never regretted going away from runflats apart from the fact that I should have gone with Contis instead of Michelin all weather tires.
I highly recommend getting non runflats and a can of fix a flat. Drivability should improve leaps and bounds over stock rfs
2021 q60 RS i-line awd
This is something people don't seem to get, winter tires aren't about snow on the ground. They're about the compound's performance in lower temperatures. It can be bone dry and if it's 30° out you still want winter tires.
Can you let me know what tires you went with?
Administrator
Reactions: Omenx and testrage
If you're looking for all seasons the go-to's are either the Michelin Pilot Sport A/S 4, or Continental Extreme Contact DWS06+. Both will be leaps and bounds better than the runflats in almost every metric.
Reactions: IridiumRS400
Jumping on the Band Wagon . . . " Ditch the Run Flats ! "
Simple fact of life is that Tire Tread wears out over the miles and age is not a good thing either
Branding and Price is a whacky too ~ a well known brand can be $100 or more per tire than a lesser known Brand Name
Here is an economical ( Yes serious too ) recommendation for an All Season ~ Performance Tire in your size
A Discount Tire Exclusive ~ ( don't laugh ) Behold the Falken G5 Pro Sport A/S
Tire Wheel Automotive tire Light Synthetic rubber
Administrator
Sumitomo brands include Dunlop Tyres, Falken Tire and Ohtsu Tire.
1 - 16 of 16 Posts
