1 - 2 of 2 Posts
title. When I leased the car I had to sign a waiver saying I couldn’t put normal chains on the car and would have to use special Nissan ones, I don’t know if anyone had to sign this paper but does anyone have any recommendations if the car can be used with chains or cables? Thank you!
If you signed a waiver I'd play it safe and use Nissan.
This is in the 2017 manual:
Tire chains/cables should not be installed
on P255/40RF19 and 265/35RF19 tires.
Doing so will cause damage to the vehicle.
If you plan to use tire chains/cables, you
should install 245/40RF19 or
P245/40RF19 tires on your vehicle.
Tire chains must be installed only on the rear wheels and not on the front wheels.
Check your manual. They're also available online:
1 - 2 of 2 Posts
