Wrong ones
Wrong onesAmazon, i will verify they work then post the link.
Yeah i bought what was supposed to be nissan 6x9 adapters for the mounting bolts. ill just drill and use self tappers. Bose is a a pita as always.The cutout is 6x9. The bolt holes are in a different place than usual. You don’t need adapters you need new holes.
I'm on the upgrade path as well. What kind of speakers/setup did you go with, and how are you liking it? Did you replace the amp too or just the speakers?Yeah i bought what was supposed to be nissan 6x9 adapters for the mounting bolts. ill just drill and use self tappers. Bose is a a pita as always.
This!!! I just put a powered 12" sub in, but I want to replace the tweeters in the door, they sound so bad with my EDM music! But I feel this will just not work wellThe mids definitely are lacking in the Bose speakers and it’s unfortunate there is no adjustment in the sound system settings. It’s very apparent in EDM music. Adjusting EQ from iPhone helps a bit but still sounds a bit off. Though I feel the lows are acceptable.
Then again, “No highs, no lows, must be Bose”
