Whose fault is that?I'm in the UK ..... it's a RHD !🤣😂🤣......
I had a 3.5 Altima with a fob port. It was shaped to receive the exact same fob for the Q60. What is pictured is not the fob port.Hmm, maybe this ?
Starting Your Nissan
With a dead Nissan key fob, you can also start your vehicle so you won’t be stranded waiting for roadside service. If you have a Nissan car, truck, or SUV that has a key fob port, place the fob in the port and tap the brake pedal or clutch as you press the START/STOP button. This can still be done even if your Nissan doesn’t have a port. Simply press the key fob against the START/STOP button as you step down on the brake of the clutch.
It's a credit card holder. Try itOn my Q60 the manual tells me to hold the fob against the start button and press the brake.
So again it aint that.
