1 - 2 of 2 Posts
HELP!!!!!hey guys i have a frustrating issue… i have a 2020 q50 3.0tt luxe. ever since i installed a magnaflow cat back system.. a few weeks later i added AMS down pipes and ever since i keep getting the p2098 code.
prob cuz i no longer have cats . what can i do to prevent this from constantly happening??????
No, it is actually unusual, even with Cat-less DPs, to get DTCs on the VR30.
Based on what I see, you should check to make sure the electrical connections to the primary O2 sensor on Bank 2 (driver's side) are seated properly and are not damaged.
P2098 Infiniti Post Catalyst Fuel Trim System Too Lean Bank 2
Possible causes
– Faulty Heated Oxygen Sensor
– Heated Oxygen Sensor harness is open or shorted
– Heated Oxygen Sensor circuit poor electrical connection
– Exhaust leaks
– Contaminated Heated Oxygen Sensor
Put another way, if it was the Cat-less DPs that ware the issue, then you would get DTCs on Bank 1 and Bank 2, but Bank 1 appears to functioning normally, even with the Cat-less DP.
1 - 2 of 2 Posts
