1 - 6 of 6 Posts
Hey Guys - wondering if anyone else here is having the same issue... Every since I lowered my Q it feels like its pulling left a bit but the strange thing is that after I do the DAS reset/realignment procedure the car sort it self out again and stops pulling left. The issue is that I have to do this every time I start the car, i.e. it will always pull left till I do a reset with the car on, then its good till I turn it off.
Anyone experiencing the same issue?
FYI I lowered my Q with RS R Lowering springs - alignment sheet below, not sure how to read it :( Any feedback on that is also much appreciated.
23103
I would suggest less aggressive camber, especially on the rear. SPL makes Adj Camber Arms to bring the Camber settings back to the stock adjustment range:
Rear Camber Arms Q50/Q60
Eccentric Camber Lockout Kit Infiniti Q50/Q60
For the front, SPL makes Adj Upper Control Arms:
Front Upper Camber/Caster Arms 370Z/G37
When I installed the RS-R Active C/Os, I had many SPL suspension bits installed at the same time to manage ride height (1" drop), toe, caster, and especially camber.
Reactions: JonnyB
Discussion Starter #4
Thanks for the tip! The thing I don't understand completely is that when I look at the "before" and "after" camber measure I don't see almost any changes, does that mean they incorrectly took the "before" after installing the new springs? That's why I wasn't too concerned about it when I saw that the measurements didn't change much. I'll have a look at these items and have a chat with my shop. Thanks!
Discussion Starter #5 (Edited)
Would this one work for my rear camber? It's about 90 bucks where the one you linked was almost 500. Why such a huge difference?
And for the front, the one you linked is almost 1k, found this one for 500: is it any good?
Overall my financial situation changed now that we've expecting a baby and I'm looking to avoid long term suspension problems without breaking the bank to fix it. Looking for tips and recommendations.
Thanks a lot!
Thanks a lot!
No worries. Yes, the SPC brand will work as a cheaper alternate to the SPL hardware.
Reactions: JonnyB
1 - 6 of 6 Posts
