1 - 12 of 12 Posts
So, I’m trying to install G37 Akebono Calipers (all 4) and rotors on my Q60 and it looks like the banjo bolt doesn’t fit, so I ordered smaller banjo bolts.
Just wondering if anyone has done something like this and has experience with it.
Do I need to replace brake lines as well or just banjo bolts for it to bolt up? The brake lines are different, but from what I can see smaller bolts should work.
Just the banjo bolts, AND don't forget about the front & rear Brake Dust Shields because the rotors are bigger.
Looks good. What wheels are those?
Youtube video for the install coming soon :), but all you need is:
-G37 (sport) akebono brakes (full set)
-G37 (FRONT ROTORS ONLY)
-4 smaller banjo bolts (Z1 Banjo Bolt )
-Red Sport 400 Rotors (REAR ROTORS ONLY)
-Cut both front and rear brake dust shields ( I used a dremel with a diamond wheel)
1 - 12 of 12 Posts
