1 - 8 of 8 Posts
Just purchased a 2014 Q60 convertible this weekend and for the life of me, I cannot figure out how to shut off the rear passenger air conditioner, which is built in like a grill, into the back of the driver and front passenger seats. It is not only blasting very loudly (which bothers me and forces me to turn up the music), but, considering most of the time it is just me in the car, I don't have a need to cool the backseat area and is causing unnecessary gas consumption. I didn't spend much time in the backseat area, just peeked to see where the sound was coming from, but did not see any sort of switch or know to shut it off. The salesman had no idea why it was blasting or how to shut it off, and I figured the manual would touch on it, but I didn't see anything like this being mentioned on the user's manual. :confused: Hoping someone else might have some insight.
I checked the manual too. I don't see where it even mentions rear passenger seat climate control. Does yours have climate controlled seats? There's a separate control for that.
The 2014 Q60 convertible is basically the G37. It also had cooled seats.
@BeachGal , do you have the cooled seats on by any chance?
Discussion Starter #4 (Edited)
Perhaps! I do have dual climate control but I assumed it meant front passenger and driver, in the traditional "dual climate control" meaning, but maybe not. I don't see any mention of rear controls on the manual or the dash/instrument panel, though I see some models have a "rear' button, like this one:
I don't know if the "heated/cooled seats" knob would control the rear passenger A/C, I assumed that it was for the backrest of the driver and front passenger seats to have heating and A/C. I will try playing around with the knobs and see if they do anything though, worth a shot.
Perhaps! I do have dual climate control but I assumed it meant front passenger and driver, in the traditional "dual climate control" meaning, but maybe not. I don't see any mention of rear controls on the manual or the dash/instrument panel, though I see some models have a "rear' button, like this one: https://www.youtube.com/watch?v=ozVVfUIugT4 I don't know if the "heated/cooled seats" knob would control the rear passenger A/C, I assumed that it was for the backrest of the driver and front passenger seats to have heating and A/C. I will try playing around with the knobs and see if they do anything though, worth a shot.
Nah I meant the "heated/cooled seats" knob. I wasn't sure if it was turned to "cooling" because when it is, the element in the seats makes a whole bunch of noise (based on the Q60 convertible I rode in at least).
Discussion Starter #6
Wow, I am such a dolt, though honestly, they *COULD* have made things more user-friendly...I started twisting the knobs around, all the way to the "hot" setting, then all the way to the "cold" setting little by little, and noticed that when I had the knobs halfway between the "cold" and the "hot" temperature control, the seats would become silent, so I was able to deduce that when putting the knob halfway between the "cold" and "hot" setting, it somehow switched off the A/C. Still, would it have killed them to put an "OFF" indicator there, rather than having people go nuts over the noise of the cooling element and wonder how to shut it off? :( Not even the manual touched on this.
That's what I figured was the issue :) . Glad you figured it out :D
I think you should contact the service center, they will help you and don't try to fix it yourself, because you can break even more, trust my experience. When I bought my wife a car six months ago, everything was fine, everything worked fine, but after a while the air conditioner started to fail. When my wife tried to turn on any function, it did not react, and when she did not touch it, it turned on itself and worked by itself. Then I asked for advice from a friend, and he advised me to contact the repair of air conditioners of any type. I went into the first one service that I saw, and they fixed everything within an hour.
1 - 8 of 8 Posts
