1 - 14 of 14 Posts
As the title mentions, my 2017 sport RWD had it's engine replaced at 60k miles. There are no modifications done to the car.
Does anyone know if this is a common thing for the VR30 regardless of how well you maintain the car/engine? Am I better off selling the car as my powertrain warranty is coming to an end?
Administrator
I guess that would depend on if you can find a car to trade for in a deal that you would walk away happy.
Have you had the car since new? What is the issue that caused your engine to be replaced?
I was not the original owner, I bought the car at 50k miles. Apart from the Carfax, I do not know if this car was maintained properly or not. It goes without saying that I can give this new engine the TLC it deserves but my chief complaint is that if the original engine was maintained and an engine failure still occurred, I would be without a powertrain warranty and in need of a new engine.
Administrator
Quick thoughts:
1) People who buy Q60 RS tend to run'em hard when they know there not going to keep.
2) Wonder what deal you could get from the dealer on a brand new one where you could maintain from the get-go?
3) I love my Q60, she is part of me so don't think I could depart without another one 😎
Reactions: 831Q60RS
I assume that with any used car it's been beat on before you got it. At this point, you've got a new engine, I'd look into getting an extended warranty if you don't already have one. Switch to 5w30 engine oil, change it every 5k.
FWIW, I also got my car used from Carmax with 44k miles on it. It was a rental before I got it. I had my trans replaced at 66k miles and the engine replaced at 68k miles. I assume that it had a rough life before me, but I essentially have an entire new drivetrain now. Anything that happens to the drivetrain from here on out I will only be able to blame myself for. 😂
I'd imagine 5w30 would be for warmer climates, but considering I live in the northeast I may leave it at 0w20.
I don't know the condition of the transmission but I guess it wouldn't be a bad idea to have an ATF service even though Infiniti claims the ATF will last for the life of the vehicle.
I had my transmission fluid drained and filled (7 qts) at 31k miles, and it has made a world of difference with the shift quality. I'd recommend it way before 100k miles.
Reactions: 831Q60RS
You could do 0w30 if you're concerned about cold weather starting, but the difference between 0w and 5w is that 0w is good down to -40 degrees C (-40F) and 5w is good down to -35 degrees C (-31F). A 30 weight under normal operating temps will better protect your engine than the 20 weight will.
I'd also recommend getting the ATF serviced.
I think the lowest cost option would be to purchase an extended warranty from infiniti, probably around $3,000+ and good for few years to ~120k miles. It's not the best time to buy a new car, unless paying up is OK with you.
2018 Q60 Red Sport AWD
Im about 35k miles, tuned & FBO for the last 5-7k miles & feel it's time to change my transmission fluid. I asked my Infiniti adviser & he mentioned to me that they do not touch the transmission fluid unless there is a problem. Not quite sure why they are hesitant to service the transmission? I know they speak of the "lifetime fluid", but i don't buy it lol! Just like they advise 10k oil change intervals hahahaha No thank you!
Curious on your take....
Do it. It's a worthwhile service to have done at your mileage.
Reactions: 831Q60RS
Agreed, and if they won't do it, find another dealership that will.
Reactions: 831Q60RS
1 - 14 of 14 Posts
