Key fob battery replacement
339 Views 5 Replies 4 Participants Last post by  Lonnaaugust
Anyone happen to know?…
I’ve got a 2021 Q60S AWD and the low battery on key (key fob) warning came up on the dash when I started my car today. Interestingly, each time I’ve started it after that the warning hasn’t come on. Anyone happen to know where in the owners manual it list the instructions to change out the battery in the key fob and what type of battery to use? * The manual shows article 3-2 entitled “battery replacement, intelligent key” but when I read that section it doesn’t say anything about battery replacement. I searched all through the manual and can’t find anything. Thx in advance if anyone knows.
1 - 6 of 6 Posts
Remove door key from the fob, there is two notches at the top, split it open with flat screw driver. Battery type is CR2032.
Reactions: 1
Thx man. Much appreciated.
Seems odd they don’t list instructions or battery type in the owners manual.
Youtube has great videos showing you exactly how to replace your Q60 FOB. The battery is labeled and easily identified. Its either a CR2025 or CR2032. WHen you take it apart you will see.
Reactions: 1
When remove door key from the fob you'll find two notches at the top, split it open with flat screw driver. Battery type is CR2032.
1 - 6 of 6 Posts
