1 - 2 of 2 Posts
Hi I was wondering is there any way to have multiple OBD connections in the Q60? Or if I should get a splitter? I am trying to connect a gauge and JB4 but I mean there's only 1 OBD port. I just head that splitters usually turn one port on and the other off and keep switching so I was wondering if any of you have any recommendations or idea to be able to connect 2 obd port mods?
I found this explanation in one of my Audi/VW forums:
Here is the issue. All OBDII communications must go through the CAN gateway. The CAN gateway can only handle one instruction at a time. It is possible to plug 2 devices into the connector with a "Y" cable. However, there will be problems if both devices try to talk to the car at the exact same time. The CAN gateway has no way to know that there are 2 devices, so it cannot address only one to send data to only one device. As long as one of the 2 devices is relatively quiet (not constantly demanding info), both devices will probably work OK. However, if one of the devices is polling for data constantly (like the Torque App running 6 gauges), I would not expect any other device to reliably communicate.
In other words, 2 devices can be plugged in at the same time, but they might not both work as intended. For any important function, I would not recommend plugging 2 devices in at the same time.
1 - 2 of 2 Posts
