1 - 1 of 1 Posts
Hello all I’m replacing my engine after spinning a rod bearing it failed because of oil thinning at higher temps, Can I use the redsport oil cooling system if so what parts would I need. Also if I can adapt the redsport oil cooler can I use a bigger aftermarket oil cooler any help is appreciated thanks in advance!
1 - 1 of 1 Posts
