1 - 2 of 2 Posts
Hello all, so i I spun another set of rod bearings in my Infiniti i recently replaced the engine with a used motor from a wrecked 2020 q50 with only 6k on the ODO. I’m wondering if it possible to replace the main bearings and rod bearings without pulling the motor; has anyone done this? Is it worth doing or is it easier to just pull the motor completely? Thanks in advance!
I am correctly having the same issues don’t want to spend the thousands of dollars to buy new engine so I am going to attempt it I hear the only think I have to worry about it putting the timing of the engine back correctly
1 - 2 of 2 Posts
