1 - 10 of 10 Posts
Greetings,
I'm trying to know which spacers I should use for the 20 oem wheels to make them look flush.
Front - 255/35/20
19x9.0 offset +40
Rear - 275/30/20
19x9.5 offset +47
I hear I need to poke close to 92mm front and rear is that the magic number to make the flush look?
A 20mm spacer on each should get you flush.
I run 15mm spacers on my OEM's in winter and it looks much better than stock fitment.
Reactions: 351FUN and EternusX
It doesn't matter than the rear is 9.5 and the front 9.0?
Nope, they basically have the same poke (or not) as the front with the different offset.
Reactions: EternusX
Reactions: EternusX
Nice info! Safe to assume that this wouldn't work for AWD Q60s and only RWD right?
As far as I know, they run the same offsets stock, so it should apply to AWD as well.
1 - 10 of 10 Posts
