Rim fitment Guide
1.4K views 3 replies 3 participants last post by  SUBSPEED
Since our seasoned members haven't replied, I will just leave some basic and general advice (that you may already know, sorry).
The reason why it's not cookie cutter and easy to answer is in the end it depends on your wheel's design if its going to come in contact with your BBK (Big Brake Kit, though ours is not a 6 pot so uh...).
No one wants to be held responsible for saying it will fit because its an educated guess there. Otherwise everything seems fine but we can't be 100% sure. For example, you want no rubbing but you also have aftermarket coilovers... so that makes it even more unlikely someone can give you the assurance you want unless they have the exact setup which...
I believe that most of the owners here also are not into track/race oriented setups like you are so you might have to just bite the bullet and actually go test it yourself at a shop.
