1 - 12 of 12 Posts
Just got my new rims and tires put on today. Wondering if I should get 10 or 15 mm spacers? Any ideas or advice. I would like to to sit flush if not stick out a tiny tiny bit.
245/19/40 Michelin pilot sport as3+
24356
24357
Do you know the full specs on the wheel? Width and offset are going to help determine what size spacer you might need/want.
245/19/40 Michelin pilot sport as3+ View attachment 24356 View attachment 24357
I have 10mm and 15mm Z1 Spacers. I did use them when I had a set of wheels that are 9.5" in width and 35mm offset.
Don't need them anymore, so you can make me an offer.
If you would sell just the 10mm spacers I am interested. I already have 15mm and want to try to the 10mm set.
Thanks!
I’m not sure where can I find that? Is it on the tire itself? All I knew was the 245/19/40. Sorry thought it was enough
Thanks!
how far out does the 15 stick out for you?
Hey man I found the info
00
19X8.5 5X114.3 ET35 D.A.I for the rims
AKUMA - GLOSS BLACK
P255/40R19 MICHELIN PILOT
I don't have the stock wheels but I mounted a set of 20mm spacers that were way too much for my wheels. I will mount 10 and 15mm at the same time to see which one is best for me. Good luck!
2017 Infiniti Q60 3.0t
I have Z1 15mm just the front because I run OEM forged rays R35 GTR wheels, it’s 20x9.5 +40 and 20x10.5 +25 I believe. I run 245/40 and 275/35 and use 15mm spacer to flush the front wheel with the fender. Check your offset to determine. Seems like 25-30 offset will get you that flush
1 - 12 of 12 Posts
