1 - 10 of 10 Posts
Greetings to all, my Q60 has this problem in the steering wheel I will leave a short video with the noise.
Does it feel strange or is it just the noise?
I had the same issue, but it wasn’t nearly as loud. The dealer determined it was a problem inside the rack and replaced it under warranty.
@Carlos and @acmethod I listen to your video, I had the same issue but my sounds was more of a pop I failed my state inspection because of it, two infiniti dealerships couldnt figure it out so they replaced the entire steering rack and pinion.
If your car is still under warranty that might be your best bet, none of the tech's at the two dealerships were able to pinpoint the actual cause of the noise, I just got my car back on the 18th and the sound is gone.
Discussion Starter #10
Can you give me the address of the dealer? I am from Virginia but apparently the mechanics here only know how to change oil and nobody wants to give me a diagnosis and the infinity of here insists that the noise is normal.
1 - 10 of 10 Posts
