The final pieces are being delivered to me this week but here are the following mods I have for my Q60. I also have Pure Stage 2 turbos on that way, however I am going to roll with the stocks first and get used to a car with power first. Here is my my mod list.
2017 Non-Redsport.
1. AMS High Pressure Feul Pump RA338
2. AMS Flex Fuel Kit
3. AMS STAGE 1 DIRECT INJECTORS
4. AMS Low Pressure Fuel Pump
5. AMS High Pressure Fuel Sensor
6. AMS Fuel Filter Kit
7. OEM VR30DDTT FUEL RAIL (LEFT)
8. OEM VR30DDTT FUEL RAIL (RIGHT)
9. AMS Heat Exchanger
10. Z1 Q60 VR30 Silicone Intercooler Coolant Hoses
11. Z1Silicone Radiator Coolant Hose Set
12. AMS Coolant Expansion Tank
13. Z1 Q60 VR30 Red Alpha Carbon Fiber AMS 14.Cold Air Intake System
15. Z1 Auxiliary Intercooler Pump Kit
16. Z1Q60 3.0t Oil Cooler Kit
17. Z1ALUMINUM SUBFRAME BUSHING
18. Z1 Q60 Brake Master Cylinder Brace
19. AFE Q60 Sway Bar Set
20. SPL PARTS REAR SWAYBAR END
21. Z1 Q50 / Q60 Street Pro R190 Limited Slip Differentia (LSD)
22. Z1 Q60 Rear Differential Brace
23. BC Racing Type BR Q60 RWD Coilovers
24.AMS Cattless FD
25.HKS SSQV4 Blow Off
26. Q60 Coupe Aluminum Undershroud
27. Z1 Q60 3.0t RWD Aluminum Oil Pan
28.Greddy Magnetic Oil Drain Plug
29.OEM Serpentine Belt
30. 2 piece Akebono Front & Rear Rotor Kit w/ Custom powder coated calipers.
31. Forged Carbon Fiber (Mirror Caps, Diffuser, Rear Spoiler, Rear Roof Spolier, C-Blades)
I am deciding between Z1 and SOHO (due to my location) for part install. I am looking forward do it.
Just thought I would share this with the Quminity
2017 Non-Redsport.
24.AMS Cattless FD
