21 - 36 of 36 Posts
Discussion Starter · #21 ·
Well, we can predict where you will NOT be taking you Q for service in the future!
Discussion Starter · #23 ·
Without a doubt! They've been bugging me to do a survey for the last few days. Did it after the new dealership told me there was oil in the downpipes. I dropped it off at the new dealer 4 days after the original dealer said "Everything's fine."
Discussion Starter · #24 ·
Got my car back today. New turbos and a new water pump. Much quieter on cold start and feels more powerful now too.
Just remember - don't go crazy with boost right off the get-go. The turbos are new, so they will need a break-in period, just like when the car was new. I'm assuming the dealership put a new oil & filter in, too?
Discussion Starter · #26 ·
Yes, oil was changed as well. Have a belt squeal under moderate acceleration now though. Calling dealer in the morning.
Discussion Starter · #28 ·
24721
belt has no more than 15k miles on it.
Discussion Starter · #30 ·
Is that something that will go away over time then?
Not sure. The coolant could have made the belt harder and with less grip. The underside should have a velvety feel.
Once the belt is contaminated, that's it. You'll be better off in the long run getting a new belt. The OEM serpentine belt P/N has been revised once.
Discussion Starter · #33 ·
AC compressor realigned and belt replaced. May that be it for a while now...
Do you have a custom exhaust ? Mine just started blowing smoke when I have it in park after my recent oil change :/ I have lower downpipes and custom 2.5 exhaust with resonators no check engine light or anything the car runs good :(
Discussion Starter · #35 ·
At the time all I had was the Infiniti helmholtz resonators, everything else in the exhaust system was factory stock. I never had a check engine light for this either.
So, this is only the 2nd time in 6 months that I've seen the exhaust smoking like this. I drove the car for about 30 minutes, then it sat for an hour, before I remote started it before leaving again. This was after running for about 12 minutes. It smoked at about this level for a few blocks too once I started driving. I have not been able to get this to happen again. Going to the dealer on Friday though to get it documented and have them look at some things.
Wondering if adding an oil catch can would help since this is so intermittent?
Exactly the symptom I had. Just replaced both turbos under Powertrain warranty. Take to dealer! 🏎 I have a post with the details under turbo issues.
21 - 36 of 36 Posts
