1 - 2 of 2 Posts
Window is pushed above door frame. To close window must be cracked then rolled up from inside. Window auto up and down dont work. Window rolls up about an inch at a time manually, then when window is finally at top it then rolls down 3/4 of way down then stops.
Door swithces all work driver and passenger mirrors memory seat buttons all work flawlessly. Dealers tells me this is common window and door track is loose rivets coming loose.
2017 Q60 RS
Administrator
2017 Q60 RS
Give this a try if you haven't already:
If the windows do not close automatically
If the power window automatic function (closing only) does not operate properly, perform the following procedure to initialize the power window system. 1. Place the ignition switch in the ON position. 2. Close the door. 3. Open the window completely by operating the power window switch. 4. Pull the power window switch and hold it to close the window, and then hold the switch more than 3 seconds after the window is closed completely. 5. Release the power window switch. Operate the window by the automatic function to confirm the initialization is complete. 6. Perform steps 2 through 5 above for other windows. If the power window automatic function does not operate properly after performing the procedure above, it is recommended you have your vehicle checked by an INFINITI retailer.
1 - 2 of 2 Posts
